I have a bathroom fan in the basement that has a 3ft horizontal run from the vent opening to the fan opening. The outside vent has a spring damper that closes tightly and the damper in the fan housing is functioning properly as well but isn't a great seal.
The ducting is a Class 1 insulated air connector and is foil taped at both ends and also has worm clamps.
I do get a slight draft coming through this fan on cold days. Any ideas why and what I can do to improve it?
