On my recent basement re-wire and main panel replacement, I wired the entire bathroom on its own 20 amp standard circuit (non-GFCI/AFCI) and just simply installed a GFCI outlet independent of the lights.
For my wet bar area, since there is an outlet behind the fridge, behind the bar (on the wall, will be under some shelving) and continues around to where it will eventually be fed into the bar itself for some counter-top outlets I put that circuit on an AFCI breaker and used GFCI outlets. I wasn't sure if it was required to be AFCI because of where some of the outlets for that circuit are in the family room downstairs.
Also, I was required to install at least one GFCI outlet in the un-finished area of the entry way from the garage in the basement, along with a couple other outlets in and around the laundry room area and down the hallway. Probably 6 or 7 outlets and most are GFCI or GFCI protected standard outlets (tamper resistant of course) and this circuit is also a AFCI circuit since there was one outlet installed in the hallway part of the "living space". Eventually the entry way will be all finished off and I can probably remove some of the GFCI outlets and use them out in the garage instead when I add some additional power out there.
Bottom Line, it certaintly won't hurt to have the AFCI protection, I haven't had ANY issues with nuisance tripping like I was fearful of (I've installed 6 AFCI circuits so far here), just overload tripping (20 amp circuit via 12 gauge extension cord to the garage with table saw, air compressor and miter saw doesn't work too well).
