New to this forum, and it seems very informative. I searched the internet as well as this forum prior to posting, so I hope im not wasting anyones time.
I am going to install a new bathtub and tile the surround next week and was looking for a little guidance. I decided to go with a steel tub instead of fiberglass or cast iron, and I noticed most of the tubs have the self leveling bottom. the instructions for a tub i did before said not to use mortar or a pad because the bottom of the tub is self leveling, so i didn't. needless to say the tub creaks like crazy now. im not sure if you should use mortar with it, or if it was because the floor i put it on didn't have any plywood down for a smooth surface, as it looked like the picture i attached. i plan on installing a plywood flooring on those 2x4's with screws and construction adhesive, sound good?
another question i had is about the lip on the bathtub. do i cover the lip of the tub that gets nailed to the studs with backer board? im sure you do, but wont the backer board bow out a little bit where the lip is? not sure how that would affect the tiles.
my final question (and thank you for bearing with me this far) is, since i am installing the tub in an enclosed area, should i frame in the mortar bed? i have no way of removing the framing once the mortar dries, so i was planning on putting the plastic sheeting down on the plywood without framing and then setting the tub into it. i think if i pour the mortar correctly i shouldn't have to worry about an excess of mortar trying to pour out from below the tub. Thanks again for your time, i appreciate it.
