helping a friend- want to do it cheap- Removed old 50's tile- He wants to install a 3 piece tub surround- I took it down to the studs and am putting up moisture-resistant drywall- in some areas the drywall pieces do not line up evenly.. meaning the left piece is a bit higher than the right piece- I'm guessing it's best to get it as even as possible as the imperfections will show thru? What is best way to get both pieces flush? shim or with joint compound?
