1 - 8 of 8 Posts
I am trying to change out a light and have two blacks (left) and a white (right). When I removed the existing, the blacks were both connected to a screw, however my new light only has one screw. Do I just connect both blacks to the one screw?
Not good wiring practice, but unless you have a wire nut and a piece of wire like you are using and make a "pigtail" like the whites have... 2 black wires under one screw will have to do, until times get better..
Super Moderator
Two wires under one screw is not permitted. You will need to put them together with a black pigtail.
Discussion Starter #5
Thanks. That is a bit of a pain. I do not have any wire lying around nor do I know an electrician in the area.
So I tried connecting both to the single screw and the second light on this switch, which I also changed, won’t come on? (The doubled up one does).
I will go and get some wire and do the pigtail as you say. But why now is the black in the second light dead?
1 - 8 of 8 Posts
