1 - 6 of 6 Posts
Where the ground meets my basement window, there is about a 2" concrete sill that is broken into about 5 pieces, exposing the tops of the cinder block wall (explains why water was coming through despite my drainage efforts). How can I go about repairing this? Obviously I can't spread concrete directly over the blocks, so what do I need to put down before the concrete?
Thanks!
Thanks!
You can spread concrete over the blocks if you stuff the openings in the blocks with a filler, crumple up some plastic bags,or use bubble wrap to fill empty space,where there's a will there's a way.
Posting a picture so we can see what your seeing is always helpfull.
Concrete & Masonry
Are you sure it's actually a concrete sill and not just a mortar "wash" over the block? If you have the room, a one-piece stone sill (like what joecaption linked to) would work well.........
1 - 6 of 6 Posts
