We had our home built in August. Now I am starting to finish my basement but noticed the windows down there are not sealed properly. So I am sealing them and the second one I noticed is not sealed but also loose.
The windows are 4x4 in poured concrete foundation. There is no metal or wood frames just concrete notches that the windows are sealed to. They are not screwed to the foundation in any way and not really any room to screw them into the foundation.
I can push on the upper right hand of the window an inch or 2 to the outside. The windows can not be pushed to the inside because of the concrete notch.
It seems like a silicone type adhesive was used in each corner of the window between the vinyl window and concrete. What kind of adhesive should I use in the corner to fix this?
You can see from the pictures of what is currently in place.
