Don't waste money on a baseboard ststem if you don't have a problem. - Water in soil moves up, down and laterally, so obviously a drainage system at or below the bottom of the footings is many times more effective and can even lower the humidity in the basement.
If you don't have a problem, don't worry about the drainage system now.
An egress window does not require attacking the lower part of the basement if it is put in according to code height requirements.
Dick
Dick
