I'm renovating my basement washroom and found some loose fitting 1/2" styrafoam which I've already tossed out. There was no vapour barrier.
Should there be a vapour barrier used when it's against concrete block? I see no signs of mold in the wall at all and its been like that for about 25-30 years I'd guess.
Should I use some styrafoam pink agianst the blocks?
The wall on the right is a cold cellar. If I insulate the wall, should I use a vapour barrier there?
Thanks.
Thanks.
