21 - 26 of 26 Posts
Discussion Starter · #22 ·
wouldn't be standard here, if a header is not needed you don't install one.
Based on what I see without the drywall, it appears to me that the wall isn’t load bearing. No header over the door. The right end doesn’t look like it’s a support post either. The left end, the studs go all the way to the floor without a bottom plate. Does that mean this left end is a support for the beam above? Thoughts?
Wood Building Flooring House Floor
Brown Wood Floor Flooring Rectangle
Wood Road surface Floor Flooring Hardwood
retired framer
I agree the main section is not load bearing but the side walls or one of them could be.
The stud going right to the floor is a hint to a bearing point or it could also mean there was a last minute change to make the non bearing wall longer.
We can't see the top of the wall so you also have a dropped ceiling.
Measure how much stud you have between the ceiling and top plate inside that wall.
You might have something like this picture and depending on how it is built and non bearing wall may be supporting the ceiling.
Property Building Wood Fixture Wood stain
Building Fixture Wood Building material Window
Discussion Starter · #24 · (Edited)
View attachment 674475 View attachment 674476
That measure the is right at 3”. Top plate to the finished side of the ceiling.
Wood Flooring Floor Wood stain Hardwood
Wood Rectangle Composite material Beige Hardwood
retired framer
So there is a 2x4 on both sides for the ceiling.
Rectangle Parallel Font Wood
You might add some angled screws thru the top of the stud into the plate to insure a good attachment.
Rectangle Font Wood Parallel Illustration
Then you could cut the studs and trim the ceiling drywall back a bit for a patch
Rectangle Wood Art Font Symmetry
Or cut the studs lower and add a 2x4 and trim it like a small beam.
Rectangle House Parallel Font Logo
Discussion Starter · #26 ·
Great info, thanks. Now I just need to figure out how to move the electrical. Lol
21 - 26 of 26 Posts
