Hi, any help is greatly appreciated with our issue.
After experiencing a slight constant leak in the finished part of our basement (coming through crack in a fireplace in basement) we decided to tear up our patio to get access to the outside wall that it faced. After tearing out the patio, digging down to the foundation and even replacing the old drain tile on 2 sides of the house (house was built in 1941) we still get a leak when there is a lot of rain.
The only other thing I can think of to do is to install a trench drain around the perimeter of the new patio concrete where water seems to sit (about 15 feet out from the house) and then drain the area to a lower part of in the back of the backyard.
Does anyone think that water that is pooling 15 feet out from our house could be causing our leak? It would have to be pooling and then draining under the concrete patio and down under the foundation and then forced up through some crack in the basement floor.
I am just running out of options and money trying to fix this problem, it also doesnt help that its been one of the rainiest years so far this spring.
Thanks in advance
Thanks in advance
