I am in the process of framing up my basement and wanted to get a few opinions on the basement steps.
As you can see below, the steps come down right against the block foundation wall. The steps need to be replaced/rebuilt. Both stringers are broken.
You can also see a support pillar and a drain vent on the other side of the steps. I will be enclosing the steps on this side in a wall and these will be hidden. I was then going to install a skirt board on this side of the steps.
The way I see it, I have two options for the side of the steps against the foundation.
#1 I can remove the steps, use furring strips against the block wall, hang drywall. Build my wall on the other side. Rebuild steps and then install skirt boards to both sides. Leaves the steps pretty narrow.
#2 I can paint the block wall (already dryloked) the same color as the room and leave it without drywall. Replace the steps, build a wall on the other side as planned to enclose the steps and skirt board 1 side.
If I went with option 2, I would have to butt the drywall perpendicular to this block wall in the corner and use caulking to fill the gap I guess. Doesn't sound like the best idea, but thought I'd get some opinions here and see if anyone had any other options.
