I'm working on adding a bathroom in our basement. The question I have is regarding the shower. The house is a 100yr old house with block foundation, where the shower will go is an area that has been dug out, so a newer block retaining wall has been installed several feet in from the exterior walls. The shower will be in the corner and about 4'x4' in size. The concrete block retaining wall is reinforced with steal and each cell was filled with concrete. This wall only comes up about 4', so I'll have to frame about another 3' on top to reach the ceiling.
My question is what is the best method to prep this area for tile?
1)Do I build the framed wall on top, but set it back enough to place cement board flush with the block and tile directly to the block then to the cement board? I'm actually thinking of building the framed wall back ~12" back from front of concrete so there is a ledge to set stuff on in shower. Plus it would eliminate cracking asking the joint. My neighbor is a brick mason, should I have him put a scratch coat on the block to even it all out? It's pretty even as it is.
2)Do I add cement board directly to the concrete block? What would be the appropriate glue for that? I figured I'd secure it in place with tap con screws.
3)Do I frame a wall up just inside the block and build as if it were on any other floor off the house?
I realize concrete/masonry is porous, so figure the walls and floors need something, but I also don't want to over kill either. FWI....I still have to pour the foor in this area as it's dug up for the plumbing. It's a liner on the floor absolutely necessary or is there a way to go without?
As it stands I need to frame about 1/4 of a wall and the jams for the door, but if I am better off with concrete block I can have neighbor add block to the ceiling height. And do the jamb sides with block. I see public showers at gyms, lake, etc and they seem to be just concrete and tile and they get heavy use, so I'm thinking a liner might not be necessary.
Thoughts, feedback on this?
