My home is 12 years old. Below ground basement was Drylocked when we bought the house. Basement was fine for a few years but now we occasionally see water. Think one of the primary sources is a bad seal on one of the windows. Easy fix. Also seeing what I believe to be moisture on one of the interior walls. Not so easy fix. This one I can't figure out. My husband thoroughly bleached the wall and applied fresh drylock about a year ago but now the block or paint is swelling and flaking off. (worse than before). How serious is this? Think we need to understand the root cause. Suggestions? What's the best way to permanently fix it? See pics attached. Have talked to a couple people and they've suggested using a wire brush to scrape off the swell. Then what? Is there a better, not so manual way to tackle it safely without damaging the blocks? THANKS SO MUCH!
