Hi All,
So after reading many of the posts on this forum, I've decided to finish my basement. I've found a number posts that deal with parts of my question, but not the entire thing.
I've currently got a layer of r-12 roll installed 4 inches from the ground by the builder. I plan on removing this garbage as soon as possible.
I've decided to go with a Rigid board against the naked cement walls - most likely the Corning CodeBord 1.5in C200 product. This will give me an r7.5 value (r5 per inch).
After insulating all of the outside walls, I plan on framing with 2x4's and then brining the r-value up by installing batt insulation (r-13 or higher). My understanding is that I require r-20 in finished living spaces in my area.
My question is about vapour barriers. My understanding is that the codebord against the walls acts as a vapour barrier, but on the Owens Corning site, they have a number of basement drawings where they install an additional vapour barrier on the 2x4s, so the order is as follows:
Concrete-->CodeBord-->Framing with batts-->Vapour barrier.
My understanding was that the vapour barrier traps moisture, so is adding the 2nd vapour barrier a bad idea? Will it trap moisture between the two barriers (codebord & plastic) and create a mold breeding ground in the wood? Vapour barrier is normally installed this way without the CodeBord, so does it really make a difference?
Should I forego the internal vapour barrier altogether? If so, why does Owens Corning recommend doing so in their product sheets?
Any help is greatly appreciated.
Joe
Joe
