1 - 20 of 32 Posts
I own a ranch house and on the main level there is a hump that runs across the whole house in the center of the floor. I went to the basement measured from the floor to the top if the beam then measured up the side of the basement wall and there was an inch and a half difference. So I'm thinking the beam is set to high and is causing this hump in the floor issue. If I lowered the support collums on the beam an inch and a half would all the door frames and wall corners show major settling cracks?
They could.
Is the beam only up in the center or is it up where it meats a basement wall too?
If the floor has heaved your doors should be not working properly.
Experienced
Hello and Welcome Jlynn024, to the best darn DIY'r site on the web.
Sounds like whoever built this place forgot about doubling the bottom plate.
I would say that lowering the center beam would not be a DIY'r job, there is just too much at risk.
Mark
Bottom plate? I'm not sure what that is? The basement is barebones unfinished. As far as lowering it, I can't at this point anyway because the Collums have no means to be adjusted. Do you have any recommendation on who would take on such a job of lowering the beam or recommend some other action? Any specific issue this may cause by DIY? Also Mae all the doors shut smoothly I'll have to check where the beam sits in the wall when I get back home.
Thanks
Experienced
Toss a level on the walls, are they plumb? If they are then my guess is it was built that way and if you start messing with the center beam everything will be thrown off.
The top or more correctly said the sill plate is the (usually 2 x 8 or 6) that sits on top of the foundation, or the foundation was never level to begin with.
Discussion Starter · #6 ·
I will check the walls tonite. I'll tell ya a theory iv kind of thought out I could defiantly use your input. The people I bought the house from put a perimeter drain in the basement under the floor all alongside the walls. Now I'm not sure but it seems as if the basement walls are settling but the beam in the center that runs the length of the house is not. Therefore there if a hump you can feel on the main level of the house. Is lowering the beam an option or any other route you might consider?
Experienced
Following your theory, I would definately have a knowledgable person out to look at what you have going on, if the parimeter walls are sinking then you need to have that resolved before you ever think about the center beam.
Mark
could you post a photo of the beam and top of foundation wall?
I believe that I would contact a local structural engineer before making any modifications. First though, I would set up a transit or laser level in the basement, and shoot the bottoms of the joists, in order to get an accurate picture of what might be going on. Obviously, something is amiss, since you can feel it on the main floor, but your basement floor is not necessarily level throughout, so using it as a gauge is not the most precise approach.
Discussion Starter · #11 ·
doesnt look like i could lower that beam period. Probably more problems than its worth any way. I dont have a laser but the beam is set at 86" but when i measure at the wall to the joice its 85. If anyone has any other advice or needs any more information from me I'd be more than happy to share. It sounds like i had better get an engineer of some sort before it gets out of hand... I have two other pics also just says they failed to upload
where the beam goes into the foundation wall it appears there is a 2x nailer on top of the steel beam. is the top of the nailer level with the 2x sill plate on top of the foundation wall?
Run a string line under the beam with a 2x4 as a spacer on each end, then all the way it should be 1.5" below the beam. If it is higher in spots where a telepost is then it may need to be lowered.
Discussion Starter · #14 ·
herea another pic of the Joices and the strange designed perimeter drain system. Which also concerns me a lilttle bit
Discussion Starter · #15 ·
yes, the 2x4 on the ibeam and the 2x4 on top of the foundation are level. The picture without the black pipe does not have a 2x4 on the top of the foundation though
if the top of the 2x4 on the steel beam is level with the top of the 2x4 on top of the foundation then it should be level. that is if your floor joists set on top of each 2x4 plate, or am I missing something?
have you put a level of the bottom of the floor joists?
Framing Contractor
Measuring from the floor means nothing. Many basement floors are sloped or just not perfectly level. A string as a reference from end to end is the only thing that will tell you if your theory is correct. Even then, you will have trouble if you try to make everything perfect now.
Discussion Starter · #19 ·
look at that... i was wondering why the darn collumns werent painted. I know the pic isnt the greatest but i think that is it. The poles nedd to be shortened.
Discussion Starter · #20 ·
I agree with you on not trying to make everything perfect. Chances are if i do make any kind of adjustment it will crack all the square corners in the entire house. I guess im going to have to deal with the hump in the floor for now. I just wonder at what point i should try and make an adjustment. Are the colums used to support the I beam designed to be adjusted? I know they usually have two ways to adjust them but are you supposed to "just set it and foget it" and not make adjustments through out the years?
1 - 20 of 32 Posts
