We are in the North GA mountains where the summer is extremely humid and can be quite warm. The winters are cold and generally low in humidity. Our problem is the summer months mostly in our garage, not so much the finished basement.
Both have concrete block walls and concrete slabs.
Each have one wall that is below grade.
The garage has a heated/cooled living space above it.
The garage does not have conditioned air.
There are no foundation vents in the garage
The air is extremely musty in the garage.
There is a problem with green mold which finds a home on sandply stock (cabinet-making wood stock) which is exposed, sitting on-end on the garage slab.
I have not seen mold on the joists, just that wood that touches the garage floor for about three feet up.
This is where the controversy begins.
One expert says do not to put in foundation vents,
another says to air condition the space,
one says to put foundation vents in,
one says to put in a dehumidifier,
one says to finish the garage with insulation on the walls and paneling.
Air conditioning doesn't make sense to me because the space is already cooler than the rest of the house, and we only run our A/C perhaps four weeks an entire season.
A dehumidifier would cost an arm and a leg to run, as it would be on 90 percent of the time during the summer.
Finishing the space doesn't make sense if most of the moisture is coming up the concrete slab.
What to do? Thanks for your input and help!
