Hello Everyone,
Brand new to the forum... and new to framing (and finishing a basement), but have done my own handy work in the past.
I've got DriCore R+ Subfloor down already and will be framing walls on top and will be using 2x4's (8ft) for everything (with 2.5"-3" screws)... framing ~1" in front of the existing insulation for external walls (concrete foundation runs halfway up the wall as the foundation is mostly above grade... the upper half is the exterior of the home, which is using 2x6's with insulation and vapour barrier).
The question isn't really which wall to start on here... it's really should I start with the main soffit around the main ductwork / electrical / gas line area that will be a bulkhead and use that as a top plate for some walls?
A lot of the main space is taken up by a wide HVAC duct that runs along the main structural metal beam, along with the main electrical trunk of wires and the main gas line...
Said wide duct/main trunk of electrical and gas also just so happens to run into the external wall in which I would like to start framing first (as I am doing this in a phased approach and would like to finish my office and the adjacent furnace room).
So should I start with the main soffit and build the (non-structural of course) external and internal walls off of that (ie: use soffit to mount wall top plate)?
I can't really put a top plate directly on the joists in these areas, as the ductwork is there on both the external and internal walls framing the first two rooms here... because without the soffit framed, the top plate would in effect be floating in mid air, attached to nothing
Any suggestions would be greatly appreciated.
Pictures and diagram of the planned build attached.
Thanks!
Best Regards,
dg6464
Thanks!
Best Regards,
dg6464
