Hello,
I have a walk-out basement that has old sheet lenolium flooring, which is flat and has no cuts or air pockets anywhere.
The room is damp but the dehumidifier does a good job of keeping up with the humidity.
Do you think the lenolium will act as an appropriate moisture barrier for those sticky vinyl tiles? Or, would I be better off putting down floating laminate flooring that has a built-in moisture barrier?
Thanks!!
Thanks!!
