1 - 20 of 20 Posts
I am in the beginning stages of undertaking a basement finishing project in my home. The previous owner had a interior french drain/weeping system installed. I have never noticed any water infiltration I the 10 years I have lived here. I did notice condensation , for some reason my wife could not understand that it is not good to leave the base entry windows open night and day from early spring until the beginning of winter. Until this past winter when I repainted the cinder block foundation, there was some crystallization the I treated, removed, scraped then wire brushed, applied an alcohol based sealer, primed then painted with two coats of paint. A year I've noticed some minor paint adhesion issues which I figured would happen since modern latex paint can lift old coatings/reveal weak spots in the old finish once the new paint has cured. I am wondering what are my insulation options for the foundation? Could I use 1" XPS on the walls even where the interior drain system is? Could I use the recommended adhesive for XPS and glue the panels in place? Then seal the joints with foam tape, seal the base to the floor with minimal expansion foam? My concern even though there is no water infiltration would the system still function if there was any condensation or moisture after being insulated in the manner I am considering ? I am also considering re insulating the rim joist area using 2" XPS , spraying minimal expanding spray foam around the perimeter of the panel, then adding fiberglass insulation, however I am confused would I use fiberglass insulation with paper or without? I am not considering closed cell sprayfoam due to being cost prohibitive in my case. I plan on using wood 2x4's for construction, first a sill gasket would be put down, I'm thinking pressure treated baseplate, then normal then regular 2x4's for the rest of the framing. I am located in Michigan, the house is a ranch with a cinder block foundation. I would appreciate if members could guide me properly. I don't want any mold issues in the future. I want to do it right and do it once, that way when I'm older I have minimal maintainance. I am any painter by trade, since my slow season is approaching I would be doing the remodel myself.
Sent from my SM-T230NU using Tapatalk
There has to be at least 2000 post on this same subject, tried using the search funtion?
Huge mistake trying to address this on the inside.
99% of the time any moisture issues needs to be addressed from the outside.
Joecaption there has no longer been evidence of moisture. I am leaning toward the fact that the previous owner a widow was taken advantage of with the installation of the French drain. Also I did use the search function, there is so much variance among the existing threads in one thread it will be said oh yeah pink XPS is fine, next thing use blue foam board, then someone mentions foil. That is why I decided to start a new thread with the facts that pertain to my basement and home state of Michigan. Thank you for your input
· Registered User
Reactions: Windows on Wash
Welcome to the forums!
Just answered one similar from same place (State anyhow); http://www.diychatroom.com/f15/alternative-drylok-345594/ lol.
Gary
PS use foil-faced fb on rims after caulking joints; Read my #6 and #10 here; http://www.diychatroom.com/f103/insulate-rim-joists-canned-spray-foam-roxul-307313/ Use fb under the plate-non-PT with f-facing to stop air/moisture/thermal better than low R-2 or so; sill sealer.
Gary, the foil faced fb you mention is that the pink, blue, or the actual blue foil with a yellowish foam board sandwiched between two layers of the foil. Now that I think of it some of the pink fb has a plastic sheet layer as well. For the rim joist a local hardware store recommends the pink 2" foam board then a fiberglass with paper following that. Hence my confusion and apprehension. I appreciate your info, I am on overload lol
· Banned
Many of the foil faced foams will be of the Polyiso variety but you can get it in either foam.
The foil makes is a Class I vapor retarder and slows the radiant energy movement.
The foil will replace the necessity for any additional vapor migration control.
Discussion Starter · #9 ·
So does the actual color of the foam board make a difference the thinner pink foam board has a clear plastic sheet on it, the 2" does not, there is a version the blue board as well that had the plastic, then there is the bluefish foil that has a yellowish core. Hence my confusion and reasoning for posting this thread. I appreciate the info everyone provides.
We have a concrete foundation and finished our basement several years ago.
Basement walls are a heat sink and you could be seeing condensation from the air and not moisture coming through the wall.
I got a roll of six mill plastic, wrapped it on a furring strip and masonry screwed through the strip into the top of the concrete wall leaving the plastic to hang. I then 2x4 famed on top of the plastic that extended at the floor on 24" centers (non-bearing wall). Then put faced 24" wide 4" fiberglass insulation batts between the studs. The sill stud is pressure treated. I also covered the floor with 6 mill plastic taped with a specific tape by 3M rated for polyethylene. Over that went felt underlayment and clic type flooring.
Discussion Starter · #13 ·
I was thinking of using this in the final joist area sealed with canned spray foam around the edges.
http://m.homedepot.com/p/Owens-Corn...uared-Edge-Insulation-Sheathing-45W/100320352
Then I was considering this product for the cinder block wall surface of the foundation.
http://m.homedepot.com/p/Owens-Corn...nd-Groove-Insulation-Sheathing-68WD/100320355
I also visited the lowes web site they offer a light greenish blue product with the same specs, hence my confusion and apprehension regarding the insulation project
Discussion Starter · #14 ·
I also wanted to add the basement is below grade, the exterior of the house is brick.
Also could anyone share their opinion on the Foamular products I mentioned in the post above, I was also considering Foamular 250 2" for the rim joist area followed with fiberglass with paper facing the interior.
I may have been causing confusion by mentioning XPS in previous posts it is extruded polystyrene the Dow Foamular 150 & 250 are pink in color.
By foil-faced, I assume you're talking about a product like this:
http://www.homedepot.com/p/Super-TU...t-R-6-5-Insulating-Sheathing-268426/100322374
Double-faced poly-iso. But, isn't poly iso very bad at dealing with water? The foil-facing prevents a problem, but the narrow edges on each side will be unfaced.
So, would you recommend sealing the four unfaced edges with aluminum tape, for a continuous foil-barrier, before installing?
Could someone offer a link to the foil faced product for the rim joist area, so as to clear up my confusion, thank you to all who participate in this thread
I linked a foil-faced polyiso, in the post just before yours. Home Depot carries it. Lowes, to my knowledge, does not.
However, polyiso (even foil faced) has a much higher water absorption percentage over XPS foam -- and especially if the foil deteriorates or is penetrated.
For foil-faced polyiso, I would, at least, think that sealing the four exposed edges with additional aluminum tape would be wise.
And, I've also heard people recommend XPS over polyiso for these humid applications.
· Registered User
Sorry if I caused any confusion. The rims should be faced foam- plastic, foil, anything with a low permanence to stop winter/summer moisture drives/condensation.
" However, especially in retrofit situations, the amount of exterior insulation that can be installed (if any) may not be sufficient to provide adequate thermal insulation (at least R-10). Thus in these cases, the alternative is to install rigid insulation (such as foil-faced polyisocyanurate) flush against the interior side of the sheathing. This still allows air drying of the rim joist cavity but reduces the potential for interior summer condensation by decreasing the condensation surface to the bare minimum of the interstices of the insulation/ sheathing interface. In the winter, the insulation is protected from interior-sourced water vapor by the foil-facing."
Granted, you wouldn't see a lot of condensation unless you added fibrous insulation in the floor cavity (directly inboard of the foam) to reduce the foam board temps there As that interface wouldn't be warmed by the room as much.
More importantly is the facing on the rim side of the foam to stop any moisture from entering the foam to keep the wood wet longer, with more time to mold. The interior faced, if foil, would also support radiant heat resistance, a good thing- if 3/4" gap. Don't use any facing and you will still be waaay better than none at all.
IMO, use a faced product on the walls as you have an interior drainage system and want to stop any moisture through the CMU to weep down and pump out. Poly will also work but only with a drainage system interior.
Gary
1 - 20 of 20 Posts
