After water came in through the window casement during the snow thawing, it's time to fix this up. The window part is fixed and now i need to take a decision on the flooring of this 132 sq. ft bedroom.
The original floor was made like this:
1" by 1" wood slats spaced out on the cement floor
mix of plywood and osb sheets (with cedar shims to level a few places)
thin plastic sheet
1/8 " foam
laminante flooring.
Time to install a floor! I've kept the original laminante flooring (95% of it is not damaged from water) but here is where i'm confused.
Should i replace the wood slats with a plastic subfloor (example: delta - FL) due to the moisture? BTW I live in Northern Ontario
What's important to me is the moisture control and a leveled floor.
What do you guys think? Anyone else gone through something simular?
thin plastic sheet
1/8 " foam
laminante flooring.
