This bath was started without putting in a vapor barrier between blocks and stud walls. Brother says its fine, I say its not. Its a dry basement and block walls have 3 coats of UGL Drylock. Only 2 walls are exterior (under ground), the other 2 are just 2x4 stud walls in open basement. Its my understanding that a vapor barrier should have been put in between the stud walls and blocks, then insulated. No insulation behind shower either. Brother says nothing goes behind shower, says we insulate other stud walls and put vapor barrier between drywall and studs. I think he is wrong.
How should this have been done and what are our options short of convincing him to tear it all out and start over?
