1 - 6 of 6 Posts
As i am slowly finishing my basement , i was wondering if anybody here has any good ideas for a basement ventilation system.
As my basement is 70 -80- % underground with poured basement walls , i was wondering a good way to add some ventilation.
I have presently no HVAC system in my house everything is electrical baseboard heating.
I have no water / moisture problems .
Just would like to refresh the air i guess .
I read about some products but found this
http://www.energyvanguard.com/blog-...-These-3-Expensive-Ventilation-System-Ripoffs
Any ideas ??
· Hvac Pro
Depends on where you live and if you have a open basement. Exhausting air requires bringing it back in and if you live in a cold climate you may want to recover the heat from the exhaust. You can get a small HRV. You need some ductwork and I would take some of the air from upstairs. Lifrebreath makes the best units IMO and have been around since the mid 70's. I have a 155 Max. A 95 may do you well.
Not DIY freindly to install so you need a contractor to set it up and balance it properly. You can read on their site about how they get installed.
http://lifebreath.com/products/residential-ventilation-hrv
Crack window open as needed - can also put an exhaust fan if there's a bathroom down there. hrv is an expensive proposition unless you need it for other reasons.
don't ventilate when its humid out, makes things worse.
even a musty or stale smell can be caused by excess humidity.
Thanks guys,
I don't have a bathroom down there but was actually thinking of installing a bathroom fan in the center of the room on a seperate switch.Turn on as needed.
Maybe on the wall instead of the actual ceiling due to low ceiling ?
That lifebreath 95 looks good as well.
1 - 6 of 6 Posts
