I am putting a 16'x16' addition on my house. I have decided to go with a full basement addition under it, which will be connected to my existing unfinished basement. I have 8" thick poured walls with brick facing. The new addition will also be done with brick faced forms. I have a few questions about this process and the contractor seems to be pretty non-chalant about it, so I thought I'd get some other opinions.
1. How should the new addition be attached? Bolts, rebar? Should the existing walls be notched out and the new ones poured within them, or just butted up?
2. My existing foundation has Form-A-Drain on the inside and socked 3" tile/rock around the outside. My soil is very sandy, and I've never had a problem with leaking in the 5 years we've been here. I have never noticed the sump pump running, even during heavy rainfall periods. So, what should I do for drainage around the addition?
3. What should I do for waterproofing on the new walls? The existing foundation has damproofing to grade.
I appreciate any info anyone can provide!
