Hi all I have been assigned to make a baptismal pool for my local church. I have made something similar using a system of plastic sheets and plywood, but it was good only for a few uses (was a little leaky). The design is the following I tried to do this with fiberglass, but I think I used the wrong type and it dried too quickly to use. I believe it was polyester and heard epoxy resin had a longer cure time. Ideally this would be something long lasting. The picture is a simple solidworks file, there is another im making composed of individual components for measurement purposes. For size it is appx 6ft wide.
Im not sure if this was the correct section but I figured water=plumbing.
Any help or comments are appreciated!
