Good Afternoon,
I am currently filling in for a engineer at my facility and i have a question. I know how to do regular 3 Lamp Ballast but i have a concern with the way some of them are set up.
I have a couple in the facility that have 2 Ballast for one 3 lamps instead of 1 single 3 lamp ballast. The one ballast is for 1 Lamp the other is for 2 lamp.
The 1 Lamp ballast has the normal Hot and Neutral wires and has a red wire and the Blue Wire
The 2 Lamp Ballast has the normal Hot and Neutral wires and has a red wire and 2 blue wires
My question is Can i use a 3 lamp blast? I know i would have to splice the Black hot wire and the neutral together and the Blue Wires will go to each blue wire for each bulb. The concern is the red wires can i splice them together.
