I am installing an inground sprinkler system. I will tap into 3/4" line in the basement below grade and run copper pipe to outside and install shut-off on the brick outside. Where I branch off the 3/4" line in the house, I was hoping to install a ball shut-off with a waste valve, but I estimate the waste valve will be approximately 19 feet away and 2-3 feet below the level of the outside shut-off.
Will the waste valve work? I would assume the line will not drain as the waste valve is below the tap. Correct?
