Hi. Before going into the issue, here is a picture of my setup on the house I recently moved into. It's pretty weird because in order to have water supplied to the sprinklers you need to have the ball valve open which allows water to flow to the misters (helps us cool down in that Arizona heat). I don't use the sprinkler system, but it would be nice to be able to without turning on the misters.
Hopefully that makes sense. So the issue I'm having is the "overflow hole" I guess you'd call it at the end of the misters' pipe is constantly leaking water. I've blocked this hole and water starts to leak out of the individual mister heads, so I've determined that the blue Everbilt ball valve shown below is leaking.
How much of a pain would this be to replace? I've done work with PVC pipe before, but never dealt with this type of ball valve. Would my best bet be installing a separate PVC ball valve for the misters' line? This would be easy, would allow me to stop the leak, and should allow me to turn on the sprinkler without turning on the misters.
I'd like to here some thoughts on my best course of action. I really appreciate it!
