1 - 7 of 7 Posts
We went on vacation for about five days and when we returned, we noticed an awful smell around our clothes dryer. We thought a wet wash cloth or towel could be the culprit but we've washed everything, cleaned the dryer thoroughly, and pulled out the dryer and the washer to make sure there was no dead rodent in the area but we found nothing and no amount of cleaning or air freshener seems to get rid of the odor. It's worse just after the dryer has been running or after opening the dryer door after it has been closed up for a while. It does smell like a dead animal but we've looked everywhere - even in the hose and can't find anything. Has anyone else encountered a problem like this? The smell initially seemed to be contained to the dryer but it seems to be now spreading througout the entire laundry area.
· General Contractor
Check and make sure nothing got into where the element is. If a mouse or other animal got in the dryer and was touching the element when the dryer was turned on, it would get electrocuted. Every time the dryer is turned on afterward would further char the remains. It makes a pretty foul smell from what I've been told.
Nasty work if there is something dead in there, but detach the vent. Unplug the dryer and look in the exhaust tube under the dryer. This is the lowest point where the squirrel cage sits. Unlikely ANYTHING COULD GET PAST THERE into the dryer itself.
Check the vent line all the way outside. If you have damper or screen on it, it is also unlikely anything could get in but if there is no cover a critter could crawl in and fall down inside. If you are unsure try to roll a tennis ball through from outside, if your vent pipe is not buried behind a wall.
A mouse could get into the element area with a lot of effort but the element is generally pretty well protected to avoid contact with clothes.
Do you have rotting smell or an acrid burned hair and cooked smell....
when this is done, install a new vent with a weighted damper. This will ensure the door closes fully outside and keep cold air out at the same time
· #1 HAWKEYE FAN
you will have to disassemble the entire dryer until you find the culprit. I've seen everything from mice to squirrels
1 - 7 of 7 Posts
