1 - 7 of 7 Posts
· Banned
No tach. I built a tach in the 70s for breaker points but I'm afraid to hook it up to this 'modern' car.
It seems to be worse at idle and with all the rain we've had lately here.
It's like one of the four cylinders switches off, but it hasn't stalled yet.
· Banned
Discussion Starter · #6 ·
FYI, resistance of the wires should be 1000 Ω/ ft max. Also check for corrosion at the wire ends.
Will do.
This 1k/' reminds me that the American cars that I measured had wire resistance all over the map but foreign cars were within a few percent of the same low value.
Maybe that's changed by now.
· Banned
The spark plug wire resistance spec limit was 25k, with the two longer wires coming in at 15k and the other two at 10k.
Two of the plugs had a gap at 0.060" instead of the spec'd 0.040" so I closed them somewhat.
A short test drive seems to say the problem is gone.
If it comes back I'll replace the dist. cap and rotor.
Thanks!
1 - 7 of 7 Posts
