A little background if you don't mind:
I've been doing many trades in construction for forty years but I'm not licensed and usually worked for licensed contractors although I did do quite a bit of handyman stuff. I stopped doing electrical and plumbing years ago out of respect for the clients and licensed pros (and to sleep better at night!) but I did quite a bit of those trades while working for licensed contractors and have advanced apprentice knowledge in those trades. I didn't feel qualified to sign up for the contractor site so here I am since I never was a contractor strictly speaking and I'm semi retired now.
I have a 2014 Gree Terra24HP230v split system and it's been fine for six years and was installed by a licensed HVAC guy. It's installed in a guest house on my brother's property. About two months ago when it was off it suddenly came on and then started going on and off very fast as if I was pressing the on button on the IR remote rapidly but erratically. I took out the batteries to rule out the remote and it still did it. I then discovered the manual override button on the unit and pushed that for thoroughness and it oddly solved the problem for about a month but then at midnight when it was off it suddenly started doing the same thing.
I also have decent shadetree electronics skills and have built my own computers, taken apart TVs and laptops etc and although I have no reason to not call the installer since my brother has to pay:smile: I really want to get some feedback before I do since I enjoy troubleshooting electronics.
There's a display panel (part #30565141) which I assume has the IR sensor in it and I'm thinking that component is shorting out. I looked up that part number and a few HVAC supply houses show no inventory across half the country and there's no sign of it on ebay or Amazon. Either it is a part that fails a lot or they just didn't make that many. I then thought I'd install the wired remote XK-76 wondering if it would override the signal path of the IR remote or would I have to remove the plug for the display panel when installing it.
Does this sound like a failing IR sensor?
Has anyone installed a wired remote for Gree mini split systems - do they get wired to the outdoor unit or the indoor?
I actually watched three videos by Gerry Wagner who does Gree installation classes for professionals mostly back East but I didn't see anything about the flaky IR issue or the wired remote.
