1 - 8 of 8 Posts
I had a contractor use Ardex resurfacing products to level my walkway. He did a horrible job at leveling the walkway and even worse is that there is a significant color difference in the concrete repair. I've contacted Ardex 3 times and they have not responded in any manner. I need to somehow seal the surface with a gray colored sealer. I'm VERY hesitant to use the Ardex sealer. What are my options?
The photos were taken on October 12 and the final surface coat was applied on September 14.
I will tell you what I have used on my own concrete patio & it has lasted for over 10 years.
Please NOTE this product is manufactured to be used on Vertical exterior Stucco walls.
This is what I used El-Rey fog coat you apply it with a garden sprayer.
You can also find fog coat from LaHabra, Omega & most likely others.
I have used large amounts on Stucco walls.
1 - 8 of 8 Posts
