Hello, I just joined DIY chatroom to hopefully get the answer to a few questions regarding my backyard drainage. I had to few quotes from landscapers, but FORGET them...toooo much money. So I figure I will do the job myself. I am handy, so no problem..
I want to connect all my gutters underground and run them to the back of my property, I have wetlands behind me and my home slopes down towards the wetlands, so that is a big plus in this project.
I plan on using solid 4 inch schedule 20 pipe (from HomeDepot). Schedule 40 required gluing pipes, etc. and I wanted to avoid that.
1. Since I am using Sch 20, I should go down deeper, correct?
2. How far down should I dig for the pipes? Is 12'-18 inches good enough for Schedule 20?
3. How wide should the trench be?
4. I can avoid using gravel under the pipe right?
5. After I connect all the gutters and run the pipes underground closer to the house, should the main pipe that goes toward the back be a 6 inch pipe to handle all the water, or is 4 inch good enough?
6. The end pipe is just going to end into the wetlands, do I need a swale or rock bed down there?
Any advice on these questions is appreciated.
Thank you
Thank you
