Stairguy
I was using my powermatic table saw today. I used it in the morning and it was fine. Later in the afternoon i went to use it and after ripping about 1" into a board, the saw started to scream. When i shut it down I noticed the blade was spinning backwards. I have never seen this before. It was about 85 degrees in the shop today and was very humid. Could this cause any kind of contact issues?
Retired Moderator
That's unheard of---That's a 220 motor? The rotation can be switched by changing the wiring inside the motor---I suspect a loose connection inside the motor cover---
Lets see what a sparky says----I would call the manufacturers technical help line,if it were me.
Retired Moderator
Wow, I have never seen a table saw do that but I did have a 16 inch older Dewalt RAS that would do that if you just turned the switch on. I was told the starter windings were bad. I always would spin the blade by hand in the right dirrection then hit the on switch and it would work fine like that. You can't spin a unisaw like that though. Let us know what you find out.
