I have a house that is in need of back flow prevention. When the storm drain floods the line backs up into the basement wash sink and also past the trap on the washer drain. No floor drains.
There is a 3" main line exiting horizontally right at basement floor level.
The washer drop and the wash sink tee are just a couple feet from the exit point.
I could put in a 3" main line backflow preventer at about $250. Would need to install horizontally. Or possibly considering 2 separate 2"check valves that I could install vertically that are only about $30 each.
The next higher drain is the first floor tub, but if we have water backing up that far we have far worse problems then then the drain.
Any thoughts?
Any thoughts?
