How should I go about putting backerboard around these non square edges?
Too big for silicone.
Excuse to buy a countor gauge. Always wanted one.chandler48; said:Not necessary, but you are going to have to do some intricate cuts on your tile![]()
If you zoom in you can see it. IIRC, Im supposed to bring backerboard within 1/16" from the top of the flange. Then silicone the gap. Then tile to within 1/16 of the flange, then silicone that gap again.No flange on that tub?
No, I am thinking of what they did to a cast iron tub. It was a drop in tub going in an alcove.Neal is likely thinking about the flat flange that most tubs have that gets nailed to the studs to ke everything in place. As to your hole, just put some thinset in it and forget it. The tile will easily span that.
Sounds right. Depending on the size of the tile that should work nice. You don't really need silicone behind, just thinset or whatever. A 1/16" gap between the tub and tile is mighty ambitious, might be better off trying for 3/32 to 1/8".If you zoom in you can see it. IIRC, Im supposed to bring backerboard within 1/16" from the top of the flange. Then silicone the gap. Then tile to within 1/16 of the flange, then silicone that gap again.
Sound right? Ive never installed an alcove tub before. She was a beast. 315lb cast iron.
HandyAndyInNC; said:Remove the sheetrock, and use only concrete backer with a waterproof coating. I would install the backer all the way to the floor. There is nothing wrong with that. I like doing that especially on the wall that is behind the tub to keep air from coming in.
