I have couple of questions on relay that is installed on my vehicle which I bought recently.
My vehicle is 2005 Dodge Magnum R/T 5.7 v8 and it has this Avital 3300L system installed in it along with the Omega RS-CH5 and QTP electric exhaust cutout (you normally have a toggle switch to open and close the exhaust flaps/valves for more sound). I have attached the pics of the relay and the toggle switches(2) that are attached to them.
Picture-4 shows the two(2) toggle switches one is large black (this is for electric exhaust) along with its ground wire ring terminal and small steel with blue plastic toggle switch(its not from Avital nor exhaust or RS-CH5).
The toggle switch for the electric exhaust works but If you see the steel toggle switch one of the black wires is connected to the relay but the other is some how disconnected because of the poor connection made, but I couldn't find out where the other wire of the toggle switch was attached too. I would get to know that if I understand the relay function in the picture.
I am aware of the relay as I already watched your video, but if u see the picture, the connections are as follows:
1) Right Relay (Aamp of America 30A/40A relay):
(i)Blue wire(86) goes to the H1/12 Orange (-) 500 mA GROUND-WHEN-ARMED OUTPUT of avital system.
(ii) Yellow wire (30 on top) goes to H1/2 Red (+)12V CONSTANT POWER INPUT of avital system. Along with that its also connected to 85 using a short yellow wire connection. This is the part I didn't get it why there is loop connection here between 30 & 85.
(iii) Red wire in the middle (87a) goes to the QTP electric cutout toggle switch ( its positive of that switch I guess)
(iv)Red wire (87) is a small wire that is connected to the 85(Yellow wire of the Left Relay which is in turn connected to its 30 by a small yellow wire). This loop connection of yellow wires between 30 & 85 is in both relays.
Left Relay:
(i) 86 (Red) goes to the H3/2 BROWN/BLACK (-) 200 mA HORN HONK OUTPUT
(ii) 87(One Black wire of that mystery small blue plastic/steel toggle switch). other end is hanging out.
87a of Left relay has nothing but the cap and its not been clamped. So I am not sure if the other end goes there or not.
The question that I have are below:
1) The other end of the steel toggle switch is hanging out not sure where it came from. Do you think that should be connected to a 12v source in order for the switch to work.
2) if the right connection is made , what is that switch used for? Is it to allow the current to flow to that electric exhaust switch or something else.
3) Why there is a loop connection in the relay itself with those yellow wires.
4) The omega RS-CH5 says that it is this feature "Aftermarket alarm Control from OEM remotes". Can I have this avital 3300l make it work with my oem remote as it says?
5) my vehicle wiring info says it has parking lights + & -, I want to connect the RS-CH5 to it since those can be used to troubleshoot the module. it looks like there may be a relay required. Can u tell me if I should use + or - wire?
wiring info for parking lights says negative requires -1670 ohms but + may needs relay and the wire is at passenger kick panel.
Can you suggest me which one to choose.
7) I also have a red push button on the lower dash similar to valet switch and I think its like a decoy for the valet switch (mine is hidden). Do u normally put them?
This wire is extended to the hood near the horn and it is combined to one wire at the end and its not connected to anything. I am thinking to use it for something good.
Can you use this Cwitch with just one wire at the end?
I know the message is large but if you have any questions regarding my question please let me know. Kindly see the attached pictures
Hope for a reply.
Thanks
Left Relay:
Hope for a reply.
Thanks
