2006 Dodge Caravan, one of the automatic door locks on a sliding door doesn't work. Is there a separate fuse or do you think it would be an actuator?
Where is the contact point?They are on the same fuse make sure the contact point on the sliding door are clean. Most likely an actuator. Just two wires power and ground remove the panel then with the door shut have someone run the door switch while you use a test light
Thank you. Very low mileage, but there is a history on Caravans of door lock problems.Put your ear up to the door panel and hit the power lock button, normally if an actuator goes out it will still try to move and make a click noise. If you can her it, its just worn out and needs replaced.
Should be on the door jam. I mostly work on fords it's been awhile since I've seen a caravan. Most contact points are copper tabs on the body side and spring loaded buttons on the door. Make sure they are clean of corrosion.rusty baker said:Where is the contact point?
