Hello and thank you for taking the time to answer my question. I am looking to install additional ventilation in my attic to decrease the temperature during the summer months and to remove stale air ( I dont think I have an issue with moisture)... The volume of the attic space is approximately 1750 cu ft (32ft L, 22ft W, 5ft H).. The volume is actually a bit less, since the roof is sloped on all four sides, not just two. There are soffits installed, but no soffit vents, and there is a gable vent w/ mesh screen at the front of the house. The gable vent is roughly 16in x 16in, which would give me about 1.8 sq ft of intake/exhaust area (minus a few points from the screen).. I know that I will have to install soffit vents if I install an attic fan, but what I would like to know is if I should install the soffit vents first and see if that alone would give me the desired airflow, before going ahead with attic fan installation.. I would also like to know if a 1000 cfm fan would be overkill for such a small attic space, especially since it is not airtight.. Going by the attic size calculations, to perform 10 air exchanges in an hour in a 1750 cu ft space (17500 cfh), I would need only a 300 cfm fan (17500/60).. I also have an old chimney which has some cracks in the bricks, so I do not want to start pulling air from unwanted areas... Also, ridge vents are not an option for me... If you need any more information, please let me know.. I can also provide pictures as well.. Thank you in advance..
- Joe
- Joe
