Inspector requires that the plywood cover to the pull down garage stairs be covered with 5/8 in dry wall...which is 54 in by 25 inch...most likely that this additional weight will prevent cover to close flush to ceiling and may allow a gap or even keep it from closing altogether...Is the spring tension system going to be enough to tack up the slack ?
