Hello to All,
We have a 2 story house [built 2004-05] and now some huge water heaters in the attic are going to soon replacing. I think I can wait until fall.
The pathway where plywood is laid down from attic door to the 2 integrated water heaters cannot be used. The heaters will not fit thru the upright rafter support beams. Therefore, I am going to have to put down some additional plywood.
The insulation in our attic is the white sprayed in type. Some has settled down below the rafter line. Before I cut and screw down some additional plywood, should I spray-in more insulation to make it flush w the rafters? Also, when laying down this additional plywood, are there any other precautionary things I should do? We could also use the extra storage and I could also free-up some critical space that is inundated w all the xxxx my wife and daughters have piled-up in the attic...it's almost impossible to get to the two AC/Heating Units bc of all the xxxx.
Thank you very much,
tstex
tstex
