My attic has blown in insulation. It is old and only about 6" thick. Much of it is settled. The floor in the attic is tongue and groove boards. Is it ok to put 2" rigid foam over the floor boards and the cover that with plywood?? Will the rigid foam cause moisture problems below? Should the foam be foil backed? Foil on top or bottom???
Thanks.
Thanks.
