I think most would say to add in soffit vents and get rid of the roof fan if that is what is meant by attic fan. But, I would think if you set it for 115 or so it would bring down the temp theoretically reducing the load on the ac system. You are fighting natural tendency of hot air to rise and exit the ridge vents by what you are planning.
See:
http://www.greenbuildingadvisor.com...nce/are-solar-powered-attic-ventilators-green
http://www.energystar.gov/index.cfm?c=diy.diy_attic_ventilation
http://www.factsfacts.com/MyHomeRepair/ventilation.htm
The main point of most of these is: "Although attic ventilation has been shown to reduce attic air temperatures and cooling loads the only examination of powered attic ventilators has shown the electricity consumption of the ventilator fans to be greater than the savings in air conditioning energy (Burch et al., 1979)." Especially if attic is R19 or higher. Fixing air leakage from conditioned space into attic would be a great move to reduce costs if the attic space is negatively pressured (from gable fan running) and drawing conditioned air into the attic.
See:
