I am refinishing my basement and replacing the basement wiring, usually from 1 central light receptacle, with in-wall wiring. My intention is to spray foam my basement and have installed 2x3 studs on a 2x4 base.
Rather than drill through all the studs to run the electrical wire, I have adequate space between the stud and the wall (typically 1-1/2") to run the wire. I can't use typical ties or staples behind the stud because of the space limitation. So I'm looking for some way to attach the wire at right angles to the stud. I've tried the screw-in cable ties but they don't twist easily.
Anyone have any ideas?
