1 - 7 of 7 Posts
This pipe (red arrow) goes into the septic tank. The elbow and vertical pipe was left as a marker and is meant to be removed.
The pipe going into tank is loose. I'm wondering how do I attach this? There is no obvious place to glue it to.
· Super Moderator
You need an adapter or heavy duty rubber seal, available at any big box store.
Can't really tell by pic, just a guess, but the tank looks like it has a 5 inch hole and the pvc pipe you are using looks like 4in.
· Super Moderator
I agree with you farmerjohn, wait till the septic installer gets back to you. He should have all the necessary fittings you need to make the proper connection or he will tell you what you need and you can pick them up at any big store.
1 - 7 of 7 Posts
