1 - 9 of 9 Posts
Hi. I'm new here.
I'm replacing the handrails, balusters and newel posts on three flights of tight "U" or return stairs. The way they're configured a couple of the handrails will have to come in along the side of the newel. The old stairs with square handrails (installed in the late 70s) just screwed them in to the side of the plain square newels. I will be using new handrails with some shape to them (standard from HD or Lowes).
Here are my questions:
(1) Could I just attach the handrails to the newel anyway from the side - screwing them in and pegging the hole?
(2) Would it be better/possible to use a metal bracket screwed to the newel and supporting the handrail (like a wall bracket but using it on the newel)?
I've looked and can't find this done anywhere so I'm not sure if it would be secure enough and/or would just look bad so it isn't done.
My alternative is to use quarter turns but I'd have to cut them down so much that there would be virtually no "turn" to them.
Thanks in advance for any suggestions.
So much easyer if you could post a picture of what you have to work around so we can see what your seeing.
Hopefully this pic helps...
Present newels are very basic 2" square poles (46" tall). I'm replacing them with 3 5/16" pieces that will connect to the side of the stringers. The rail going down the stairs in this pic will now connect right into the newel straight on because the new newel will be wide enough to allow that. But the one coming down in this pic will still run right by the side of the new newel.
Thanks again. Edit: My apologies for the sideways pic.
· Roofmaster
If this is for a child, I would be very concerned with the babys head getting caught in some of the side openings you are showing in those pictures. The four inch ball rule is in effect for a reason, my friend.
Discussion Starter · #6 ·
Here is an example of the kind of metal bracket (something like it) that I'm wondering if I might use to connect the new handrails to the side of the newel where they join it from the side. http://www.amazon.com/Stanley-Desig...sr=8-1&keywords=handrail+bracket+satin+nickel
And here is an example of a quarter turn that I might also use to connect in to the side of the newels if I cut them down almost all the way to the elbow. http://www.homedepot.com/p/t/202088...+turn+stair&storeId=10051&N=5yc1v&R=202088494
Any opinions appreciated.
Discussion Starter · #8 ·
OK, but my big question is - what fittings? I don't see any way around having the handrails come alongside the newels on a few of these. In those circumstances do I just screw them right in to the side of the newel, use brackets or use a very cut down elbow/quarter turn?
1 - 9 of 9 Posts
