I have an exterior door with 2 sidelights on either side which is actually one piece. The house is wood siding and no porch cover, just a stoop, but very traditional. I am looking to purchase a broken pediment for above the door with the attached sidelights. The total width of this is 63". I also need to cover some metal flashing that is between top of door trim and the trim to be replaced. Where do I begin?
· www.doors4home.com
I would definitely check with your local lumber yard as any broken doors or accessories would be "in-stock". This would be a good place to start.
Outside of that contact a local handyman/contractor for any advise with what you are looking for. The deminsions are not uncommon and you are sure to find what you are looking for - a contractor may even quote you for building a new pediment.
Good Luck!
Jason
