Hello. I have a wood fence that rubs on the side of my house, and is extremely loud. I have been thinking about fastening the post to the house, but that requires me to go through our vinyl siding. I do understand that the vinyl needs room to expand and contract (make a bigger hole than the screw), and that UV Resistant Silicone Caulk is the best bet for outdoors, but is this really the only way? If I do go this way, should I use a large, counersunk lag bolt, or several long, exterior screws? I was also toying with the idea of cutting out the vinyl, installing J-Channel around the post, and caulking that in, but the post is about 4 1/2 feet into the ground with around 100 lbs. of concrete (high wind load and large gate installed on the post). This also would require me replacing the cross members and an extra board on the fence. So, as a homeowner, and general know-nothing when it comes to building and being a professional, I am relying on your help. Thank you in advance!
:stupid:
:stupid:
