The trick is to do the post first and then fit the joist around them.Plan was to install the post to the framing.
Post needed right under the triple joist. Both of the 2x10's, splice right at the triple joist. Not ideal. I tried to zoom in a better photo so show.
We are in Atlanta, GA. Per the prescriptive deck manual and deck plan that was approved for the permit the footings need to be 12" deep. Do you recommend we dig deeper?
Thanks Nealtw- inspector comes next week for the footings holes before we can poor concrete so I'll try and be here to ask what they will want.We would have to see what the city wants. It is different in many places.
You would not likely do what we do.
What is frost depth where you live. Are your holes deeper than that?Thanks Nealtw- inspector comes next week for the footings holes before we can poor concrete so I'll try and be here to ask what they will want.
Agree and splice should not have lined up with triple joist- IMHO poor planning.The trick is to do the post first and then fit the joist around them.
Why do you have a 3 ply joist there?
Frost line is 5" in our zip code.What is frost depth where you live. Are your holes deeper than that?
I have not seen a bracket for that, Hopefully the inspector will come up with an idea.Agree and splice should not have lined up with triple joist- IMHO poor planning.
I noticed the framing had the splice for the 2x10's where it wouldn't line up with a post. I pointed it out to the builder and when I got home they had redone and cut out a section with the "new" splice right at the triple. I asked how the post would be attached and he said they would use a bracket.
I've been researching and haven't come across a bracket for this situation. I'm sure this has happened before and there is a solution but I want to make sure it's correct and will pass inspection and we are thinking ahead as the post for the handrails and pergola posts still also need to be attached.
The triple beam is due to a bay window.
Sorry about the bad photo angle of the framing- yes, the holes are dug directly under the frame and the intent was to attach the posts to the (2) 2x10 frame directly- not have a cantilever.I live in Young Harris (100 miles north of you) and the footing depth is a minimum of 12". It looks as if you are on a hill. Our inspector requires full continuous footing for the length of the deck, 24" deep and 12" wide. The added depth is due to the lack of soil cohesion on the precipice of the hill. Theory is that the entire deck won't slide off the hill if the footing is continuous.
I know it is a parallax view, but are the footings under the rim directly, or will there be a beam across it forming a cantilever?
Your question about the cantilever got me thinking... could we forgo the plan of attaching the 6x6 posts to the rim joist and build a beam right at the end of the joist to preserve the area under the deck for the patio space?I live in Young Harris (100 miles north of you) and the footing depth is a minimum of 12". It looks as if you are on a hill. Our inspector requires full continuous footing for the length of the deck, 24" deep and 12" wide. The added depth is due to the lack of soil cohesion on the precipice of the hill. Theory is that the entire deck won't slide off the hill if the footing is continuous.
See if they would approve a Simpson AC6Z on the outside of the post and rim and a LPC6Z on the inside. (Add framing to pad beam out to 5.5)Is there a bracket or best practice for this that will be structurally sound and pass inspection?
Looks promising. I will ask inspector. Thanks!See if they would approve a Simpson AC6Z on the outside of the post and rim and a LPC6Z on the inside. (Add framing to pad beam out to 5.5)
thanks for the comments- agree on the frame- there have been a couple of missed opportunities which is why I'd like to plan everything out moving forward.Interesting you have the frame up before the foundation and posts. Missed the opportunity to do tabs on the 6x6 and bolting through the framing.
I'd personally do 24" of concrete, regardless of code, because it is a deck and on a hill.Maybe set the posts in 6-12" from the edge, but you'd need to add a beam the whole length, minimal cantilever but still looking normal, and use metal braces atop the posts to fasten to beam and the deck.Actually that beam idea in the image is better. Or maybe just put the posts forward 1 1/2 inches ... with a shoulder and tab to bolt through. No extra beam needed. Guess the inspector may decide for you what would be appropriate.
For the retaining wall, I'd use a drainage tube the whole length, with the sock over it and ample gravel / crushed stone at the base of the wall, before using regular soil, to improve drainage.
