Ive built a driveway/ garage and in doing so I excavated 2 stations of my sprinkler system. I pulled back the the 2 feed lines and cut them off with plenty of space to easily splice new feed line and reinstall the sprinkler heads. The reinstall is relatively straight forward and entails hooking three Toro 800 heads to one line and four to the other. It's the same number of heads I originally removed.
I called in my trusty sprinkler contractor and he gave me an estimate that still has me twitching, almost 1/2 of the price of my entire 13 station system. I'm a contractor ( not landscape) as well and think the job entails ~20 hours of work digging trenches and installing sprinkler heads. So I'm going for it.
My problem is I know nothing about the system controls on the Toro controller and valve boxes. And that's my dilemma.
I can turn each of the two stations on in the valve box out in the yard by mechanically turning the valve on. However, I can't activate the two lines through the Toro Custom Command Controller (CC-P15). I think my sprinkler contractor somehow turned them off when he turned on my system this spring. The rest of the system Is active.
any advice is greatly appreciated.
